 Siebel VB Language Reference > Methods Reference for Siebel VB > ODBC Methods >
ODBC Open Connection Method
The ODBC Open Connection method is a Siebel VB method that establishes a connection to an ODBC data source. It returns a long integer that identifies a unique connection ID that you can use with other ODBC methods. If you include the outputString argument, then it returns the completed connection string in the outputString argument.  If it cannot establish a connection, then it returns an ODBC error with a negative numeric value. You can test for this value. For more information, see ODBC Get Errors Method. Format
SQLOpen(connectString, [outputString][, prompt])
The following table describes the arguments that you can use with this method.
    connectString  |
    A string or string variable that includes the following information:
- Data source name
 - User ID
 - Password
 - Any other information that the driver requires to make a connection with the data source
The connectString argument typically uses the following format: "DSN=dataSourceName;UID=loginID;PWD=password"
However, it must use the format that the ODBC driver requires. Some parts of this string might not be required. For more information on the string you use to access a Siebel application, see Siebel Technical Note #206 on My Oracle Support.  |
    outputString  |
    A string variable that holds the completed connection string.  |
    prompt  |
    One of the following integers that specifies when to display the driver dialog box:
- 1. 	Always display the driver dialog box.
 - 2. 	Display the driver dialog box only when the specification is not sufficient to make the connection.
 - 3	. 	Display the driver dialog box only when the specification is not sufficient to make the connection. Dialog boxes that are not required are not available and cannot be modified.
 - 4	. Do not display the driver dialog box. If the connection is not successful, then return an error.
If you do not include the prompt argument, then Siebel VB uses value 2.  |
 Example
The following example opens the data source named SblTest, gets the names in the ODBC data sources, and then closes the connection: Sub Button_Click    Dim outputStr As String    Dim connection As Long    Dim prompt As Integer    Dim action As Integer    Dim qualifier As String    Dim datasources(1 To 50) As Variant    Dim retcode As Variant        prompt = 4    Set ret = TheApplication.NewPropertySet()
     ' Open the datasource "SblTest" with a user name of sa, _    password of sa    connection = _    SQLOpen("DSN=SblTest;UID=sa;PWD=sa",outputStr,prompt:=4)     action = 1 ' Get the names of the ODBC data sources
     retcode = SQLGetSchema(connection:=connection, _       action:=1, _
        qualifier:=qualifier, _       ref:=datasources())
     ' Close the data source connection    retcode = SQLClose(connection) End Sub
