 Siebel VB Language Reference > Methods Reference for Siebel VB > ODBC Methods >
ODBC Save Results to File Method
This Siebel VB method gets the results of a query and stores them in a file. It returns one of the following values:
- Successful. It returns a variant that contains the number of rows that exist in the result set.
 - Not successful. It returns -1 (negative one).
The arguments must be named arguments. For information about named arguments, see Comments and Call Subroutine Method. Format
SQLRetrieveToFile(connection, destination[, columnNames][, columnDelimiter])
The following table describes the arguments that you can use with this method.
    connection  |
    The long integer that the ODBC Open Connection method returns.  |
    destination  |
    A string or string variable that contains the file name and path to this file. This method stores the results in this file.  |
    columnNames  |
    This argument can include one of the following values:
- Not zero. The first row contains the column headers according to database schema requirements.
 - 0. Does not get the column headers.
The default value is 0.  |
    columnDelimiter  |
    The string this method uses to separate each field in a row. If you do not include the columnDelimiter argument, then it uses a tab character to separate each field.  |
 Example
The following example opens a connection to a data source and saves information to a file: Sub Button_Click    'Declarations
   Dim connection As Long    Dim destination(1 To 50, 1 To 125) As Variant    Dim retcode As long
   'open the connection
   connection = SQLOpen("DSN = SblTest",outputStr,prompt: = 3)
   ' Run the query
   query = "select * from customer"     retcode = SQLExecQuery(connection,query)
     'Place the results of the previous query in the file     'named by filename and put the column names in the file     'as the first row.    'The field delimiter is %
      filename = "c:\myfile.txt"       columnDelimiter = "%"       retcode = SQLRetrieveToFile(connection: = connection, _       destination: = filename, columnNames: = 1, _       columnDelimiter: = columnDelimiter)
      retcode = SQLClose(connection)
End Sub
