Siebel VB Language Reference > Methods Reference for Siebel VB > Object Querying Methods > Compare Object Expressions OperatorThe Compare Object Expressions operator compares two object expressions. It returns one of the following values:
You can use this method to determine if an object variable is set to Nothing. For more information, see Remove Object Method. FormatobjectExpression Is objectExpression The following table describes the arguments that you can use with this method. ExampleFor examples of using the Compare Object Expressions operator, see Date and Time Methods and Get COM Object Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
