| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Object Querying Methods > Is Expression a Date MethodThe Is Expression a Date method determines if an expression evaluates to a date that Siebel VB allows. It returns one of the following values:
 For more information, see Variants. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example adds a number to the current date value and determines if it is still a valid date. In this example, a valid date is in the range of January 1, 100, through December 31, 9999: Sub Button_Click  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
