Siebel VB Language Reference > Methods Reference for Siebel VB > Object Querying Methods > Is Object Of Class MethodThe Is Object Of Class method determines if an object is of a given class. It returns one of the following values:
You can use this method only in an If statement. FormatIf Typeof objectVariable Is className Then... You must use this format. You cannot combine this method with a Boolean operator. The following table describes the arguments that you can use with this method. You use the following format to determine if an object does not belong to a class:
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
