| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Conversion Methods > Convert Expression to Double-Precision MethodThe Convert Expression to Double-Precision method converts the value that the expression argument contains to a double-precision number. It returns this number. Note the following:
 For more information, see Numeric Data Types That Siebel VB Uses. FormatFor information about the arguments that you can use with this method, see Argument That You Can Use with Conversion Methods. ExampleThe following example calculates the square root of 2 as a double-precision, floating-point value and displays it in scientific notation: Sub Button_Click  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
