Siebel VB Language Reference > Methods Reference for Siebel VB > Conversion Methods > Convert Expression to Integer MethodThe Convert Expression to Integer method converts the value that the expression argument contains to an integer and rounds the result. It returns this result. Note the following:
For more information, see Numeric Data Types That Siebel VB Uses. FormatFor information about the arguments that you can use with this method, see Argument That You Can Use with Conversion Methods. ExampleThe following example calculates the average of ten golf scores: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
