Siebel VB Language Reference > Methods Reference for Siebel VB > Conversion Methods > Convert Expression to Single-Precision MethodThe Convert Expression to Single-Precision method converts the value that the expression argument contains to a single-precision, floating-point number. It returns this number. Note the following:
For more information, see Numeric Data Types That Siebel VB Uses. FormatFor information about the arguments that you can use with this method, see Argument That You Can Use with Conversion Methods. ExampleThe following example calculates the factorial of a number. For more information, see About the Factorial: Sub Button_Click factorial = 1 |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
