Siebel VB Language Reference > Methods Reference for Siebel VB > Conversion Methods > Convert Expression to String MethodThe Convert Expression to String method converts an expression to a string. It returns one of the values described in the following table depending on the data type of the expression. FormatFor information about the arguments that you can use with this method, see Argument That You Can Use with Conversion Methods. ExampleThe following example uses the Convert Expression to String method to operate on a string that the user enters as a number: Sub Button_Click msgtext = Cstr(var1) msgtext = "The first digit you entered was," & msgtext |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
