Siebel VB Language Reference > Methods Reference for Siebel VB > Conversion Methods > Convert Expression to Variant MethodThe Convert Expression to Variant method converts an expression to a variant. It returns this variant. It accepts any type of expression. It creates the same result that assigning the expression to a variant variable creates. FormatFor information about the arguments that you can use with this method, see Argument That You Can Use with Conversion Methods. ExampleThe following example converts a single variable to a variant variable: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
