Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods > Get File Names MethodThe Get File Names method is a standard Visual Basic method that returns the first file name it finds that matches the value in the pathname argument and that possesses the attributes that you specify in the attributes argument. If it does not find a file, then it returns a null string (""). FormatDir[$] [(pathname[, attributes])] For information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method.
Usage for the Attributes ArgumentYou can use the integer values for the attributes argument described in the following table to return a specific type of file. You can add values to choose multiple attributes. For example, to return normal files, hidden files, and system files, you set the attributes argument to 6, where 6 equals 0 plus 2 plus 4. If you set the attributes argument to 8, then this method returns one of the following values:
Usage for the Pathname ArgumentThe pathname argument can include a drive specification and the following wildcard characters: Siebel VB interprets a null string ("") in the pathname argument as the current directory. This value is equivalent to a period (.). You can use the Get File Names method again to get more matching file names, but this time do not include the pathname argument or the attributes argument. ExampleThe following example lists all the files that reside on drive A: Sub Button_Click ReDim A(100) |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
