Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods > Get Free File Number MethodThe Get Free File Number method returns the lowest unused file number. It does not include arguments. You can use it if you must supply a file number and must make sure that this file number is not already in use. You can use the return value in a subsequent Open statement. FormatExampleThe following example opens a file and assigns to it the next file number that is available: Sub Button_Click Related Topics |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
