Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods >
Open File Method
The Open File method opens a file for input or output. It does not return a value. Siebel CRM opens the file in the default character encoding that the local operating system uses. This method does not support Unicode.
Format
Open filename [For mode] [Access access] [lock] As [#]filenumber [Len = reclen]
The following table describes the arguments that you can use with this method.
Argument
Description
filename
A string or string expression that identifies the name of the file to open. If this file does not exist, then this method creates it if opened in one of the following modes:
  • Append
  • Binary
  • Output
  • Random Modes
This file must be open before Siebel VB can perform any input or output operation on it.
mode
A keyword that identifies the purpose for which this method opens the file. If you do not include the mode argument, then this method defaults the mode to random.
access
A keyword that identifies the method to access the file. If you do not include the access argument for random or binary modes, then the Open File method attempts to access the file in the following order:
  1. Read Write
  2. Write
  3. Read
lock
A keyword that designates the access method that other processes can use to open this file. If you do not include the lock argument, then other processes can open the file that the filename argument identifies. Other processes cannot perform any file operation on the file while the original process still has the file open.
filenumber
An integer that identifies the file while it is open. You can use the Get Free File Number method to find the next available value that you can use in the filenumber argument. For more information, see Get Free File Number Method.
reclen
In a random or binary file, the length of the records. This method ignores the reclen argument for the following modes:
  • Input
  • Output
  • Append
Usage
The following table describes the keywords that you can use with this method.
Type of Keyword
Keyword
Description
Mode
Input
Reads data from the file sequentially.
Output
Puts data into the file sequentially.
Append
Adds data to the file sequentially.
Random
Gets data from the file by random access.
Binary
Gets binary data from the file.
Access
Read
Reads data only from the file.
Write
Writes data only to the file.
Read Write
Reads or writes data to the file.
Lock
Shared
Read or write is available on the file.
Lock Read
Only read is available.
Lock Write
Only write is available.
Lock Read Write
No read or write is available.
Example
The following example opens a file for random access, gets the contents of the file, and then closes the file. The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses:
(general) (declarations)
Option Explicit
Declare Sub CreateFile
Sub CreateFile
      ' Put the numbers 1-10 into a file
   Dim x as Integer
   Open "c:\temp001" for Output as #1
   For x = 1 to 10
      Write #1, x
   Next x
   Close #1
End Sub
Sub Button_Click
   Dim acctno as String * 3
   Dim recno as Long
   Dim msgtext as String
   Call CreateFile
   recno = 1
   newline = Chr(10)
   Open "c:\temp001" For Random As #1 Len = 3
   msgtext = "The account numbers are:" & newline
   Do Until recno = 11
         Get #1,recno,acctno
         msgtext = msgtext & acctno
         recno = recno + 1
   Loop
   Close #1
      Kill "c:\temp001"
End Sub
Siebel VB Language Reference Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
