| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods > Set File Attributes MethodThe Set File Attributes method sets the file attributes for a specified file. It does not return a value. You cannot use a wildcard in the pathname argument. If the file is open, you can modify the file attributes, but only if it is opened for Read access. FormatThe following table describes the arguments that you can use with this method.
 UsageThe following table describes the attributes you can modify. ExampleFor an example, see Select Case Statement.  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
