Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods > Unlock File MethodThe Unlock File method controls access to an open file. It does not return a value. You must use the Lock File method and the Unlock File method in pairs to unlock a file, and the arguments that you use with these methods must be identical. For more information, see Specifying the Start Argument and End Argument. You must remove a lock before you close the file. For more information, see Removing Locks. FormatUnlock [#]filenumber[, {record | [start] To end} ] The following table describes the arguments that you can use with this method.
ExampleFor an example of the Unlock statement, see Lock File Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
