Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Get Line From File MethodThe Get Line From File method reads a line from a sequential file, and then saves it in a string variable. It does not return a value. You can use it to read lines of text from a text file where a carriage return separates each data element. You can use a read method to read data from a file that includes values and commas that separate each of these values. Format ALine Input [#] filenumber, varName Format BArgumentsThe following table describes the arguments that you can use with this method. ExampleThe following example reads the contents of a sequential file line by line up to a carriage return, and then displays the result. The CreateFile subroutine creates the (general) (declarations) Sub CreateFile Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
