 Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods >
Parse File Contents Method
The Parse File Contents method reads data from a sequential file, and then saves this data to different variables. It does not return a value. Format
Input [#]filenumber, variable[, variable]...
The following table describes the arguments that you can use with this method.
    filenumber  |
    The file number that the Open statement uses to open the file.  |
    variable  |
    One or more variables to contain the values that this method reads from the file. A comma separates each variable.  |
 Example
The following example does the following work:
- Prompts a user for an account number.
 - Opens a file.
 - Searches the file for the account number.
 - Displays the matching letter for that number.
This example uses the Input statement to increase the value of x and at the same time to get the letter associated with each value. The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses: (general) (declarations) Option Explicit Declare Sub CreateFile
Global x as Integer Global y(100) as String
Sub CreateFile ' Put the numbers 1-10 and letters A-J into a file    Dim startletter    Open "c:\temp001" for Output as #1    startletter = 65    For x = 1 to 10       y(x) = Chr(startletter)       startletter = startletter + 1    Next x    For x = 1 to 10       Write #1, x,y(x)    Next x    Close #1 End Sub
Sub Button2_Click    Dim acctno as Integer    Dim msgtext    Call CreateFile start: acctno = 2    If acctno<1 Or acctno>10 then       Goto start:    End if    x = 1    Open "c:\temp001" for Input as #1    Do Until x = acctno       Input #1, x,y(x)    Loop       msgtext = "The letter for account number " & x & " is: " _          & y(x)    Close #1       Kill "C:\TEMP001" End Sub
