Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Print Spaces MethodThe Print Spaces method prints a number of spaces. It returns a string of spaces in the target of a Print statement. You can use it only in a Print statement. To determine the number of spaces to print, it uses different rules according to the following values:
You can use the Set File Width statement to set the width of a print line. For more information, see Set File Width Method. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example prints five spaces and the following string to a file: This example divides 15 by 10 with a remainder of 5 to determine the five spaces: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
