| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Print Data to File MethodThe Print Data to File method prints data to an open file. It does not return a value. You can use the following methods in a Print statement:
 The Print statement supports only elementary Visual Basic data types. For more information on parsing this statement, see Get Characters From File Method. FormatPrint [#][filenumber,] expressionList [{;|, }] The following table describes the arguments that you can use with this method.
 Usage for the Expression ListYou can use one of the following characters to separate each value in the expressionList argument:
 If you do not specify a semicolon or a comma, then the Print Data to File method creates a CR-LF (carriage return - line feed) pair and the next Print statement prints on the next line.  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
