Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Set Print Position MethodThe Set Print Position method sets the current print position. It does not return a value. You can use it only in a Print statement. Position number 1 is the leftmost print position. This method sets the new print position according to one of the following values of the position:
You can use the Set File Width statement to set the width of a print line. For more information, see Set File Width Method. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example prints the octal values for the numbers from 1 through 25. It uses the Set Print Position method to insert five character spaces between the values: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
