| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Write Data to File MethodThe Write Data to File method writes data to an open sequential file. It does not return a value. You must open the file in output mode or in append mode. If you do not include the expressionList argument, then it writes a blank line to the file. For more information, see Lock File Method. The Write statement places quotes around the string that it writes to the file. FormatWrite [#]filenumber[, expressionList] The following table describes the arguments that you can use with this method.
 ExampleThe following example writes a variable to a file according to a comparison of the last saved time of the file and the current time: Sub Button_Click Related Topics |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
