 Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods >
Set File Width Method
The Set File Width method sets the output line width for an open file. It does not return a value. Format
Width [#]filenumber, width
The following table describes the arguments that you can use with this method.
    filenumber  |
    The file number that the Open statement uses to open the file. For more information, see Open File Method.  |
    width  |
    An integer expression that specifies the width of the output line. A value of zero (0) specifies that no line length limit exists. The default value is zero (0).  |
 Example
For an example, see Print Spaces Method
