Siebel VB Language Reference > Methods Reference for Siebel VB > Code Setup and Control Methods > Send Keystrokes MethodThe Send Keystrokes method sends keystrokes to an active Microsoft Windows application. It does not return a value. It can send a keystroke only to the currently active application. You can use the AppActivate statement to activate an application. You cannot use this method to send keys to an application that does not run in Microsoft Windows. FormatThe following table describes the arguments that you can use with this method. Specifying Alphanumeric CharactersTo specify an alphanumeric character, you enter it in the string argument. For example, to send the character a, you use Specifying Control KeysTo specify that the user must press the SHIFT, ALT, or CTRL key simultaneously with a character, you prefix the character with one of the following values: You can use parentheses to specify that the user must press the SHIFT, ALT, or CTRL key with a group of characters. For example, Control Keys That the Send Keystrokes Method InterpretsThe following table describes some keys that the Send Keystrokes method interprets. To specify one of these characters as a literal value, you must enclose the character in curly brackets ({}). For example, if the string argument contains You can use the following format to send a bracket: Repeating the Same KeyTo send the same key multiple times, you can enclose the character in curly brackets ({}), add a space, and then specify the number of keys to send. For example, the following code sends 20 X characters: Sending Nonprintable KeysThe following table describes how you can to send a nonprintable key. You can use a special keyword and enclose it in curly brackets ({}).
Combining KeywordsYou can use the following characters to combine some keywords: For example, You can send multiple keywords. For example, the following code sends 25 up arrows: ExampleThe following example starts the Microsoft Windows Phone Dialer application and dials a phone number that the user enters: Sub Button_Click Related Topics |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
