Siebel VB Language Reference > Methods Reference for Siebel VB > Code Setup and Control Methods > Use Clipboard MethodsThe Use Clipboard methods are standard Visual Basic methods that allow you to use the Microsoft Windows clipboard as an object. They do not return a value. You can use the Microsoft Windows Clipboard to transfer text to and from other applications that support this clipboard. FormatClipboard.Clear The following table describes the arguments that you can use with these methods. The following table describes the statements that you can use the clipboard. The following table describes the arguments that you can use with these methods. If code or if a cut or copy operation places data that is of the same format as the data that currently resides in the clipboard, then the current data on the clipboard is lost. ExampleThe following example places the following text string on the clipboard: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
