Siebel VB Language Reference > Methods Reference for Siebel VB > Code Control Statements > Rem StatementThe Rem statement identifies a line of code as a comment in Visual Basic code. It does not return a value. A code line that begins with a single quote (') also identifies a comment. FormatExampleThe following example code is attached to a button on the Account Form applet that counts the number of corresponding child contact records: Dim i as Integer Rem Test this from the Account Contacts View Rem GetBusComp here returns a reference set oBC = me.BusObject.GetBusComp("Contact") Rem FirstRecord positions you at the i = oBC.FirstRecord Rem Returns 0 if fails, 1 if succeeds else While i = 1 |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
