| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Code Control Statements > Me StatementThe Me statement is standard Visual Basic shorthand that refers to the currently used object. It does not return a value. A Siebel VB module can be attached to an application object. If this application object encounters a some events, then Siebel VB might call a subroutine. For example, if the user clicks a button, then the Me statement runs Visual Basic code or a statement calls a method on an application object. A subroutine in this situation can use the Me variable to reference the object that starts the event. For example, the button click. You can use the Me statement the same way that you use any other object variable except that you can use the Assign COM Object statement to set Me. Format AWith Me Format BArgumentsThe following table describes the arguments that you can use with this method. ExampleFor an example, see Modify Variable Statement. Related TopicsDate and Time Methods  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
