Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Convert Number to String MethodThe Convert Number to String method converts a number to a string. It returns a string representation of this number. It uses the following precision in the returned string:
FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleThe following example prompts the user to enter two numbers. It adds these numbers, and then displays them as a concatenated string: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
