Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Compare Strings OperatorThe Compare Strings operator is a standard Visual Basic operator that compares the contents of two strings. It returns one of the following values: If the string argument or if the pattern argument is NULL, then it returns NULL. The Compare Strings operator performs a comparison according to the current configuration of the Set String Comparison method. For more information, see Set String Comparison Method. For more information about operators, see About Expressions. FormatThe following table describes the arguments that you can use with this method. UsageThe following table describes characters that you can use in the pattern argument. A range or list can occur in a single set of square brackets. The Compare Strings operator matches ranges according to their ANSI values. In a range, the value in startchar must be less than the value in endchar. ExampleThe following example determines if a letter is lowercase: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
