Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Get Right String MethodThe Get Right String method returns a portion of a string beginning at the end of the string. Note the following:
FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method.
ExampleThe following example searches for the BMP extension in a file name that the user enters. If it does not find the file, then it activates the Paintbrush application. It uses the Option Compare Text statement to accept uppercase or lowercase letters for the file name extension. For more information, see Set String Comparison Method: Option Compare Text |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
