Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Get Substring MethodThe Get Substring method returns a portion of a string, starting at a location in the string that you specify. It allows you to get a substring from a string. It accepts any type of string, including numeric values, and converts the input value to a string. To modify a portion of a string, see Replace String Method. FormatMid[$](string, start[, length]) For information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method.
ExampleThe following example returns the last name in a string that the user enters: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
