Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods >
Replace String Method
The Replace String method replaces part or all of one string with another string. It returns the string that the stringVar argument contains. Format
Mid (stringVar, start[, length]) = string
The following table describes the arguments that you can use with this method.
stringVar |
The string that this method modifies. |
start |
An integer that identifies the position in stringVar at which to begin replacing characters. The position of the first character in a string is 1. |
length |
An integer that identifies the number of characters to replace. |
string |
The string that this method places into stringVar. |
Usage
This method replaces characters starting at the start position to the end of the string in the following situations:
- You do not include the length argument.
- The string that the string argument contains is shorter than the value that the length argument contains.
This method does the following:
- If the start value is larger than the number of characters in stringVar, then it appends the string that the string argument contains to stringVar.
- If length plus start is greater than the length of stringVar, then it replaces characters only up to the end of stringVar.
- If the value in the start argument is greater than the number of characters that exist in stringVar, then it creates an error at runtime.
The Replace String method never modifies the number of characters in the stringVar argument. Example
The following example replaces the last name in a custom string with asterisks (*): Sub Button_Click Dim username as String Dim position as Integer Dim count as Integer Dim uname as String Dim replacement as String username = "Chris Smith" uname = username replacement = "*" Do position = InStr(username," ") If position = 0 then Exit Do End If username = Mid(username,position + 1) count = count + position Loop For x = 1 to Len(username) count = count + 1 Mid(uname,count) = replacement Next x End Sub
