Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Remove Spaces From String MethodThe Remove Spaces From String method removes leading spaces from a string. It returns a copy of this string with the leading spaces removed. It accepts any type of string, including numeric values, and converts the input value to a string. If the value that the string argument contains is NULL, then this method returns a Null variant. For more information, see Variants. FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleThe following example removes the leading spaces from a string: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
