Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Trim Trailing Spaces From String MethodThe Trim Trailing Spaces From String method copies a string, and then removes any trailing spaces that exist in that copy. It returns a string with all trailing spaces removed. Note the following:
FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleFor an example, see Right-Justify String Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
