Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Trim Spaces From String MethodThe Trim Spaces From String method removes leading and trailing spaces from a string. It returns a copy of this string with the leading and trailing spaces removed. Note the following:
FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleFor an example, see Get Substring Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
