 Siebel VB Language Reference > Using Siebel VB > About Data Types >
Type Characters
Siebel VB can use a special character as the suffix of the name of a function, variable, or constant. This character identifies the data type of the variable or function. It is a declaration.  Table 5 lists the characters you can use as a suffix.
Table 5.	Characters You Can Use as a Suffix
    Dynamic String  |
    Integer  |
    Long Integer  |
    Single-precision floating-point  |
    Double-precision floating-point  |
    Currency, exact fixed point  |
