以下是 OpenBoot 命令 printenv 的输出样例。每个服务器的输出可能有所不同。
{0} ok printenv Variable Name Value Default Value ttya-rts-dtr-off false false ttya-ignore-cd true true keyboard-layout reboot-command security-mode none No default security-password No default security-#badlogins 0 No default verbosity min min diag-switch? false false local-mac-address? true true fcode-debug? false false scsi-initiator-id 7 7 oem-logo No default oem-logo? false false oem-banner No default oem-banner? false false ansi-terminal? true true screen-#columns 80 80 screen-#rows 34 34 ttya-mode 9600,8,n,1,- 9600,8,n,1,- output-device virtual-console virtual-console input-device virtual-console virtual-console auto-boot-on-error? false false load-base 16384 16384 auto-boot? true true os-root-device network-boot-arguments boot-command boot boot boot-file boot-device /pci@301/pci@2/scsi@0/di ... disk net multipath-boot? false false boot-device-index 0 0 use-nvramrc? false false nvramrc error-reset-recovery boot boot
如果 printenv 输出中的任何值被截断,您可以键入 printenv 后跟变量名称来查看完整条目。例如:
{0} ok printenv boot-device boot-device = /pci@301/pci@2/scsi@0/disk@w5000cca0566c32b5,0:a disk net
