If you configure virtual local area networks (VLANs), for example, for in-band network management, remember that VLANs share bandwidth on a network and require additional security measures.
Define VLANs so as to separate sensitive clusters of systems from the rest of the network. This decreases the likelihood that users will gain access to information on these clients and servers.
Assign a unique native VLAN number to trunk ports.
Limit the VLANs that can be transported over a trunk to only those that are strictly required.
Disable VLAN Trunking Protocol (VTP), if possible. Otherwise, set the following for VTP: management domain, password and pruning. Then set VTP into transparent mode.
