Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: June 2017
Start the Host Console
  • At the Oracle ILOM prompt, type:
    -> start /HOST/console [-option]
    where option can be:
    –f | –force
    Enables a user with a console (c) role to take control of the console from any current user and force that user into view mode. If you use this option, other users receive warnings that their connections have been forced into read-only mode. When a user ends a console session that used the force option, read-write status is restored to the next user in line, with the most recent user’s read-write status being restored first.
    –script
    Bypasses the confirmation prompt to start the console.
    After the host console has started you see system console output if Oracle Solaris is running. The OpenBoot ok prompt displays if Oracle Solaris is not running.
Related Information
