Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: June 2017
OpenBoot Prompt
When the host is powered on but the OS is not booted, you communicate with the OpenBoot firmware. OpenBoot firmware displays ok as its prompt.
For more details about OpenBoot, refer to the Oracle OpenBoot 4.x Administration Guide at http://www.oracle.com/goto/openboot/docs.
This table lists the common tasks that are performed at the ok prompt.
Task
For More Information
Boot the host.
Configure OpenBoot parameters.
Run diagnostics.
Refer to the service manual for your server, detecting and managing faults.
Reset and power off the host.
At the OpenBoot prompt, type help reset to display details about the reset command.
Eject media.
At the OpenBoot prompt, type help eject to display details about the eject command.
Related Information
