Describes steps to import a model
To import a model into the Oracle Real-Time Integration Business Insight application:
Figure 3-18 Import Model Dialog
When you import a model from one system to another, the connections will need to be re-configured by a user with an InsightAdmin role. Generally, connections from one environment may be invalid in another environment (e.g., firewall issues, different network segments, development vs. production environments). Thus, importing a model only creates stubs (name only) of the connections used in the imported model, if connections with the same ID do not exist already. The user with the InsightAdmin role will subsequently need to fill in the details for these stubbed connections before the imported model can be activated.Figure 3-19 Imported Connections
If a connection of the same internal name has already been defined, the following message appears.
Figure 3-20 Skipped Connections
