This chapter provides a reference to Colt aggregate functions provided in Oracle Continuous Query Language (Oracle CQL). Colt aggregate functions are based on the Colt open source libraries for high performance scientific and technical computing.
For more information, see Functions.
This chapter includes the following section:
Table 11-1 lists the built-in aggregate Colt functions that Oracle CQL provides.
Table 11-1 Oracle CQL Built-in Aggregate Colt-Based Functions
Built-in function names are case sensitive and you must use them in the case shown (in lower case).
In stream input examples, lines beginning with h (such as h 3800) are heartbeat input tuples. These inform Oracle Stream Explorer that no further input will have a timestamp lesser than the heartbeat value.
In relation output examples, the first tuple output is:
-9223372036854775808:+
This value is -Long.MIN_VALUE() and represents the largest negative timestamp possible.
For more information, see:
Note that the signatures of the Oracle CQL Colt aggregate functions do not match the signatures of the corresponding Colt aggregate functions.
Consider the following Colt aggregate function:
double autoCorrelation(DoubleArrayList data, int lag, double mean, double variance)
In this signature, data is the Collection over which aggregates will be calculated and mean and variance are the other two parameter aggregates which are required to calculate autoCorrelation (where mean and variance aggregates are calculated on data).
In Oracle Event Processing, data will never come in the form of a Collection. The Oracle CQL function receives input data in a stream of tuples.
So suppose our stream is defined as S:(double val, integer lag). On each input tuple, the Oracle CQL autoCorrelation function will compute two intermediate aggregates, mean and variance, and one final aggregate, autoCorrelation.
Since the function expects a stream of tuples having a double data value and an integer lag value only, the signature of the Oracle CQL autoCorrelation function is:
double autoCorrelation (double data, int lag)
In Oracle CQL, the where clause is applied before the group by and having clauses. This means the Oracle CQL statement is invalid:
<query id="q1"><![CDATA[ select * from InputChannel[rows 4 slide 4] as ic where geometricMean(c3) > 4 ]]></query>
Instead, you must use the Oracle CQL statement shown in the following example:
<query id="q1"><![CDATA[ select * from InputChannel[rows 4 slide 4] as ic, myGeoMean = geometricMean(c3) where myGeoMean > 4 ]]></query>
Syntax
Purpose
autoCorrelation is based on cern.jet.stat.Descriptive.autoCorrelation(DoubleArrayList data, int lag, double mean, double variance). It returns the auto-correlation of a data sequence of the input arguments as a double.
This function has semantics different from lag1.
This function takes the following tuple arguments:
double1: data value.
int1: lag.
Examples
Consider the query qColtAggr1. Given the data stream SColtAggrFunc with schema (c3 double), the query returns the relation.
<query id="qColtAggr1"><![CDATA[ select autoCorrelation(c3, 0) from SColtAggrFunc ]]></query>
Timestamp Tuple 10 5.441341838866902 1000 6.1593756700951054 1200 3.7269733222923676 1400 4.625160266213489 1600 3.490061774090248 1800 3.6354484064421917 2000 5.635401664977703 2200 5.006087562207967 2400 3.632574304861612 2600 7.618087248962962 h 8000 h 200000000
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + 1.0 1200: - 1.0 1200: + 1.0 1400: - 1.0 1400: + 1.0 1600: - 1.0 1600: + 1.000000000000002 1800: - 1.000000000000002 1800: + 1.0 2000: - 1.0 2000: + 0.9999999999999989 2200: - 0.9999999999999989 2200: + 0.999999999999999 2400: - 0.999999999999999 2400: + 0.9999999999999991 2600: - 0.9999999999999991 2600: + 1.0000000000000013
Syntax
Purpose
correlation is based on cern.jet.stat.Descriptive.correlation(DoubleArrayList data1, double standardDev1, DoubleArrayList data2, double standardDev2) . It returns the correlation of two data sequences of the input arguments as a double.
double1: data value 1.
double2: data value 2.
Examples
Consider the query qColtAggr2. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr2"><![CDATA[ select correlation(c3, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple 10 1, 0.5, 40.0, 8 1000 4, 0.7, 30.0, 6 1200 3, 0.89, 20.0, 12 2000 8, 0.4, 10.0, 4 h 8000 h 200000000
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + 2.0 1200: - 2.0 1200: + 1.5 2000: - 1.5 2000: + 1.333333333333333
Syntax
Purpose
covariance is based on cern.jet.stat.Descriptive.covariance(DoubleArrayList data1, DoubleArrayList data2). It returns the correlation of two data sequences (see Figure 11-1) of the input arguments as a double.
Figure 11-1 cern.jet.stat.Descriptive.covariance
Examples
Consider the query qColtAggr3. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr3"><![CDATA[ select covariance(c3, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + 50.0 1200: - 50.0 1200: + 100.0 2000: - 100.0 2000: + 166.66666666666666
Syntax
Purpose
geometricMean is based on cern.jet.stat.Descriptive.geometricMean(DoubleArrayList data). It returns the geometric mean of a data sequence (see Figure 11-2) of the input argument as a double.
Figure 11-2 cern.jet.stat.Descriptive.geometricMean(DoubleArrayList data)
Note that for a geometric mean to be meaningful, the minimum of the data values must not be less than or equal to zero.
Examples
Consider the query qColtAggr6. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr6"><![CDATA[ select geometricMean(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 34.64101615137755 1200: - 34.64101615137755 1200: + 28.844991406148168 2000: - 28.844991406148168 2000: + 22.133638394006436
Syntax
Purpose
geometricMean1 is based on cern.jet.stat.Descriptive.geometricMean(double sumOfLogarithms). It returns the geometric mean of a data sequence (see Figure 11-3) of the input arguments as a double.
Figure 11-3 cern.jet.stat.Descriptive.geometricMean1(int size, double sumOfLogarithms)
Examples
Consider the query qColtAggr7. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr7"><![CDATA[ select geometricMean1(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + Infinity 1000: - Infinity 1000: + Infinity 1200: - Infinity 1200: + Infinity 2000: - Infinity 2000: + Infinity
Syntax
Purpose
harmonicMean is based on cern.jet.stat.Descriptive.harmonicMean(int size, double sumOfInversions). It returns the harmonic mean of a data sequence as a double.
Examples
Consider the query qColtAggr8. Given the data stream SColtAggrFunc with schema (c3 double), the query returns the relation.
<query id="qColtAggr8"><![CDATA[ select harmonicMean(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 5.441341876983643 1000: - 5.441341876983643 1000: + 5.778137193205395 1200: - 5.778137193205395 1200: + 4.882442561720335 1400: - 4.882442561720335 1400: + 4.815475325819701 1600: - 4.815475325819701 1600: + 4.475541862878903 1800: - 4.475541862878903 1800: + 4.309563447664887 2000: - 4.309563447664887 2000: + 4.45944509362759 2200: - 4.45944509362759 2200: + 4.5211563834502515 2400: - 4.5211563834502515 2400: + 4.401525382790638 2600: - 4.401525382790638 2600: + 4.595562422157167
Syntax
Purpose
kurtosis is based on cern.jet.stat.Descriptive.kurtosis(DoubleArrayList data, double mean, double standardDeviation). It returns the kurtosis or excess (see Figure 11-4) of a data sequence as a double.
Figure 11-4 cern.jet.stat.Descriptive.kurtosis(DoubleArrayList data, double mean, double standardDeviation)
Examples
Consider the query qColtAggr12. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr12"><![CDATA[ select kurtosis(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + -2.0 1200: - -2.0 1200: + -1.5000000000000002 2000: - -1.5000000000000002 2000: + -1.3600000000000003
Syntax
Purpose
lag1 is based on cern.jet.stat.Descriptive.lag1(DoubleArrayList data, double mean). It returns the lag - 1 auto-correlation of a dataset as a double.
This function has semantics different from autoCorrelation.
Examples
Consider the query qColtAggr14. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr14"><![CDATA[ select lag1(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + -0.5 1200: - -0.5 1200: + 0.0 2000: - 0.0 2000: + 0.25
Syntax
Purpose
mean is based on cern.jet.stat.Descriptive.mean(DoubleArrayList data). It returns the arithmetic mean of a data sequence (see Figure 11-5) as a double.
Figure 11-5 cern.jet.stat.Descriptive.mean(DoubleArrayList data)
The following table lists the input types and the corresponding output types:
| Input Types | Output Types |
| INT | DOUBLE |
| BIGINT | DOUBLE |
| FLOAT | DOUBLE |
| DOUBLE | DOUBLE |
Examples
Consider the query qColtAggr16. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr16"><![CDATA[ select mean(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 35.0 1200: - 35.0 1200: + 30.0 2000: - 30.0 2000: + 25.0
Syntax
Purpose
meanDeviation is based on cern.jet.stat.Descriptive.meanDeviation(DoubleArrayList data, double mean). It returns the mean deviation of a dataset (see Figure 11-6) as a double.
Figure 11-6 cern.jet.stat.Descriptive.meanDeviation(DoubleArrayList data, double mean)
Examples
Consider the query qColtAggr17. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr17"><![CDATA[ select meanDeviation(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 5.0 1200: - 5.0 1200: + 6.666666666666667 2000: - 6.666666666666667 2000: + 10.0
Syntax
Purpose
median is based on cern.jet.stat.Descriptive.median(DoubleArrayList sortedData). It returns the median of a sorted data sequence as a double.
| INT | DOUBLE |
| BIGINT | DOUBLE |
| FLOAT | DOUBLE |
| DOUBLE | DOUBLE |
If the input type is INT, then return type will also be INT and it will be floor of the divided value.
Examples
Consider the query qColtAggr18. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr18"><![CDATA[ select median(c3) from SColtAggrFunc ]]></query>
Syntax
Purpose
moment is based on cern.jet.stat.Descriptive.moment(DoubleArrayList data, int k, double c). It returns the moment of the k-th order with constant c of a data sequence (see Figure 11-7) as a double.
Figure 11-7 cern.jet.stat.Descriptive.moment(DoubleArrayList data, int k, double c)
int1: k.
double2: c.
Examples
Consider the query qColtAggr21. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr21"><![CDATA[ select moment(c3, c1, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 5000.0 1200: - 5000.0 1200: + 3000.0 2000: - 3000.0 2000: + 1.7045E11
Syntax
Purpose
pooledMean is based on cern.jet.stat.Descriptive.pooledMean(int size1, double mean1, int size2, double mean2). It returns the pooled mean of two data sequences (see Figure 11-8) as a double.
Figure 11-8 cern.jet.stat.Descriptive.pooledMean(int size1, double mean1, int size2, double mean2)
double1: mean 1.
double2: mean 2.
Examples
Consider the query qColtAggr22. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr22"><![CDATA[ select pooledMean(c3, c3) from SColtAggrFunc ]]></query>
Syntax
Purpose
pooledVariance is based on cern.jet.stat.Descriptive.pooledVariance(int size1, double variance1, int size2, double variance2). It returns the pooled variance of two data sequences (see Figure 11-9) as a double.
Figure 11-9 cern.jet.stat.Descriptive.pooledVariance(int size1, double variance1, int size2, double variance2)
double1: variance 1.
double2: variance 2.
Examples
Consider the query qColtAggr23. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr23"><![CDATA[ select pooledVariance(c3, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 25.0 1200: - 25.0 1200: + 66.66666666666667 2000: - 66.66666666666667 2000: + 125.0
Syntax
Purpose
product is based on cern.jet.stat.Descriptive.product(DoubleArrayList data). It returns the product of a data sequence (see Figure 11-10) as a double.
Figure 11-10 cern.jet.stat.Descriptive.product(DoubleArrayList data)
Examples
Consider the query qColtAggr24. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr24"><![CDATA[ select product(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 1200.0 1200: - 1200.0 1200: + 24000.0 2000: - 24000.0 2000: + 240000.0
Syntax
Purpose
quantile is based on cern.jet.stat.Descriptive.quantile(DoubleArrayList sortedData, double phi). It returns the phi-quantile as a double; that is, an element elem for which holds that phi percent of data elements are less than elem.
double2: phi; the percentage; must satisfy 0 <= phi <= 1.
Examples
Consider the query qColtAggr26. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr26"><![CDATA[ select quantile(c3, c2) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 36.99999988079071 1200: - 36.99999988079071 1200: + 37.799999713897705 2000: - 37.799999713897705 2000: + 22.000000178813934
Syntax
Purpose
quantileInverse is based on cern.jet.stat.Descriptive.quantileInverse(DoubleArrayList sortedList, double element). It returns the percentage phi of elements <= element (0.0 <= phi <= 1.0) as a double. This function does linear interpolation if the element is not contained but lies in between two contained elements.
double1: data.
double2: element.
Examples
Consider the query qColtAggr27. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr27"><![CDATA[ select quantileInverse(c3, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 1.0 1000: - 1.0 1000: + 0.5 1200: - 0.5 1200: + 0.3333333333333333 2000: - 0.3333333333333333 2000: + 0.25
Syntax
Purpose
rankInterpolated is based on cern.jet.stat.Descriptive.rankInterpolated(DoubleArrayList sortedList, double element). It returns the linearly interpolated number of elements in a list less or equal to a given element as a double.
The rank is the number of elements <= element. Ranks are of the form{0, 1, 2,..., sortedList.size()}. If no element is <= element, then the rank is zero. If the element lies in between two contained elements, then linear interpolation is used and a non-integer value is returned.
double2: element.
Examples
Consider the query qColtAggr29. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr29"><![CDATA[ select rankInterpolated(c3, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 1.0 1000: - 1.0 1000: + 1.0 1200: - 1.0 1200: + 1.0 2000: - 1.0 2000: + 1.0
Syntax
Purpose
rms is based on cern.jet.stat.Descriptive.rms(int size, double sumOfSquares). It returns the Root-Mean-Square (RMS) of a data sequence (see Figure 11-11) as a double.
Figure 11-11 cern.jet.stat.Descriptive.rms(int size, double sumOfSquares)
Examples
Consider the query qColtAggr30. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr30"><![CDATA[ select rms(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 35.35533905932738 1200: - 35.35533905932738 1200: + 31.09126351029605 2000: - 31.09126351029605 2000: + 27.386127875258307
Syntax
Purpose
sampleKurtosis is based on cern.jet.stat.Descriptive.sampleKurtosis(DoubleArrayList data, double mean, double sampleVariance). It returns the sample kurtosis (excess) of a data sequence as a double.
Examples
Consider the query qColtAggr31. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr31"><![CDATA[ select sampleKurtosis(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + NaN 1200: - NaN 1200: + NaN 2000: - NaN 2000: + -1.1999999999999993
Syntax
Purpose
sampleKurtosisStandardError is based on cern.jet.stat.Descriptive.sampleKurtosisStandardError(int size). It returns the standard error of the sample Kurtosis as a double.
int1: data value.
Examples
Consider the query qColtAggr33. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr33"><![CDATA[ select sampleKurtosisStandardError(c1) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + Infinity 1200: - Infinity 1200: + Infinity 2000: - Infinity 2000: + 2.6186146828319083
Syntax
Purpose
sampleSkew is based on cern.jet.stat.Descriptive.sampleSkew(DoubleArrayList data, double mean, double sampleVariance). It returns the sample skew of a data sequence as a double.
Examples
Consider the query qColtAggr34. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr34"><![CDATA[ select sampleSkew(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + NaN 1200: - NaN 1200: + 0.0 2000: - 0.0 2000: + 0.0
Syntax
Purpose
sampleSkewStandardError is based on cern.jet.stat.Descriptive.sampleSkewStandardError(int size). It returns the standard error of the sample skew as a double.
Examples
Consider the query qColtAggr36. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr36"><![CDATA[ select sampleSkewStandardError(c1) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + -0.0 1000: - -0.0 1000: + Infinity 1200: - Infinity 1200: + 1.224744871391589 2000: - 1.224744871391589 2000: + 1.01418510567422
Syntax
Purpose
sampleVariance is based on cern.jet.stat.Descriptive.sampleVariance(DoubleArrayList data, double mean). It returns the sample variance of a data sequence (see Figure 11-12) as a double.
Figure 11-12 cern.jet.stat.Descriptive.sampleVariance(DoubleArrayList data, double mean)
Examples
Consider the query qColtAggr38. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr38"><![CDATA[ select sampleVariance(c3) from SColtAggrFunc ]]></query>
Syntax
Purpose
skew is based on cern.jet.stat.Descriptive.skew(DoubleArrayList data, double mean, double standardDeviation). It returns the skew of a data sequence of a data sequence (see Figure 11-13) as a double.
Figure 11-13 cern.jet.stat.Descriptive.skew(DoubleArrayList data, double mean, double standardDeviation)
Examples
Consider the query qColtAggr41. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr41"><![CDATA[ select skew(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + NaN 1000: - NaN 1000: + 0.0 1200: - 0.0 1200: + 0.0 2000: - 0.0 2000: + 0.0
Syntax
Purpose
standardDeviation is based on cern.jet.stat.Descriptive.standardDeviation(double variance). It returns the standard deviation from a variance as a double.
| INT | DOUBLE |
| BIGINT | DOUBLE |
| FLOAT | DOUBLE |
| DOUBLE | DOUBLE |
Examples
Consider the query qColtAggr44. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr44"><![CDATA[ select standardDeviation(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 5.0 1200: - 5.0 1200: + 8.16496580927726 2000: - 8.16496580927726 2000: + 11.180339887498949
Syntax
Purpose
standardError is based on cern.jet.stat.Descriptive.standardError(int size, double variance). It returns the standard error of a data sequence (see Figure 11-14) as a double.
Figure 11-14 cern.jet.stat.Descriptive.cern.jet.stat.Descriptive.standardError(int size, double variance)
Examples
Consider the query qColtAggr45. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr45"><![CDATA[ select standardError(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 3.5355339059327378 1200: - 3.5355339059327378 1200: + 4.714045207910317 2000: - 4.714045207910317 2000: + 5.5901699437494745
Syntax
Purpose
sumOfInversions is based on cern.jet.stat.Descriptive.sumOfInversions(DoubleArrayList data, int from, int to). It returns the sum of inversions of a data sequence (see Figure 11-15) as a double.
Figure 11-15 cern.jet.stat.Descriptive.sumOfInversions(DoubleArrayList data, int from, int to)
Examples
Consider the query qColtAggr48. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr48"><![CDATA[ select sumOfInversions(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.025 1000: - 0.025 1000: + 0.058333333333333334 1200: - 0.058333333333333334 1200: + 0.10833333333333334 2000: - 0.10833333333333334 2000: + 0.20833333333333334
Syntax
Purpose
sumOfLogarithms is based on cern.jet.stat.Descriptive.sumOfLogarithms(DoubleArrayList data, int from, int to). It returns the sum of logarithms of a data sequence (see Figure 11-16) as a double.
Figure 11-16 cern.jet.stat.Descriptive.sumOfLogarithms(DoubleArrayList data, int from, int to)
Examples
Consider the query qColtAggr49. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr49"><![CDATA[ select sumOfLogarithms(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 3.6888794541139363 1000: - 3.6888794541139363 1000: + 7.090076835776092 1200: - 7.090076835776092 1200: + 10.085809109330082 2000: - 10.085809109330082 2000: + 12.388394202324129
Syntax
Purpose
sumOfPowerDeviations is based on cern.jet.stat.Descriptive.sumOfPowerDeviations(DoubleArrayList data, int k, double c). It returns sum of power deviations of a data sequence (see Figure 11-17) as a double.
Figure 11-17 cern.jet.stat.Descriptive.sumOfPowerDeviations(DoubleArrayList data, int k, double c)
This function is optimized for common parameters like c == 0.0, k == -2 .. 4, or both.
int1: k.
double2: c.
Examples
Consider the query qColtAggr50. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr50"><![CDATA[ select sumOfPowerDeviations(c3, c1, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 10000.0 1200: - 10000.0 1200: + 9000.0 2000: - 9000.0 2000: + 6.818E11
Syntax
Purpose
sumOfPowers is based on cern.jet.stat.Descriptive.sumOfPowers(DoubleArrayList data, int k). It returns the sum of powers of a data sequence (see Figure 11-18) as a double.
Figure 11-18 cern.jet.stat.Descriptive.sumOfPowers(DoubleArrayList data, int k)
int1: k.
Examples
Consider the query qColtAggr52. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr52"><![CDATA[ select sumOfPowers(c3, c1) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 3370000.0 1200: - 3370000.0 1200: + 99000.0 2000: - 99000.0 2000: + 7.2354E12
Syntax
Purpose
sumOfSquaredDeviations is based on cern.jet.stat.Descriptive.sumOfSquaredDeviations(int size, double variance). It returns the sum of squared mean deviation of a data sequence (see Figure 11-19) as a double.
Figure 11-19 cern.jet.stat.Descriptive.sumOfSquaredDeviations(int size, double variance)
Examples
Consider the query qColtAggr53. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr53"><![CDATA[ select sumOfSquaredDeviations(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 0.0 1000: - 0.0 1000: + 25.0 1200: - 25.0 1200: + 133.33333333333334 2000: - 133.33333333333334 2000: + 375.0
Syntax
Purpose
sumOfSquares is based on cern.jet.stat.Descriptive.sumOfSquares(DoubleArrayList data). It returns the sum of squares of a data sequence (see Figure 11-20) as a double.
Figure 11-20 cern.jet.stat.Descriptive.sumOfSquares(DoubleArrayList data)
Examples
Consider the query qColtAggr54. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr54"><![CDATA[ select sumOfSquares(c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 1600.0 1000: - 1600.0 1000: + 2500.0 1200: - 2500.0 1200: + 2900.0 2000: - 2900.0 2000: + 3000.0
Syntax
Purpose
trimmedMean is based on cern.jet.stat.Descriptive.trimmedMean(DoubleArrayList sortedData, double mean, int left, int right). It returns the trimmed mean of an ascending sorted data sequence as a double.
int1: left.
int2: right.
Examples
Consider the query qColtAggr55. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr55"><![CDATA[ select trimmedMean(c3, c1, c1) from SColtAggrFunc ]]></query>
Timestamp Tuple 10 0, 0.5, 40.0, 8 1000 0, 0.7, 30.0, 6 1200 0, 0.89, 20.0, 12 2000 1, 0.4, 10.0, 4 h 8000 h 200000000
Syntax
Purpose
variance is based on cern.jet.stat.Descriptive.variance(int size, double sum, double sumOfSquares). It returns the variance of a data sequence (see Figure 11-21) as a double.
Figure 11-21 cern.jet.stat.Descriptive.variance(int size, double sum, double sumOfSquares)
| INT | DOUBLE |
| BIGINT | DOUBLE |
| FLOAT | DOUBLE |
| DOUBLE | DOUBLE |
Examples
Consider the query qColtAggr57. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr57"><![CDATA[ select variance(c3) from SColtAggrFunc ]]></query>
Syntax
Purpose
weightedMean is based on cern.jet.stat.Descriptive.weightedMean(DoubleArrayList data, DoubleArrayList weights). It returns the weighted mean of a data sequence (see Figure 11-22) as a double.
Figure 11-22 cern.jet.stat.Descriptive.weightedMean(DoubleArrayList data, DoubleArrayList weights)
double2: weight value.
Examples
Consider the query qColtAggr58. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr58"><![CDATA[ select weightedMean(c3, c3) from SColtAggrFunc ]]></query>
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 35.714285714285715 1200: - 35.714285714285715 1200: + 32.22222222222222 2000: - 32.22222222222222 2000: + 30.0
Syntax
Purpose
winsorizedMean is based on cern.jet.stat.Descriptive.winsorizedMean(DoubleArrayList sortedData, double mean, int left, int right). It returns the winsorized mean of a sorted data sequence as a double.
int1: left.
int2: right.
Examples
Consider the query qColtAggr60. Given the data stream SColtAggrFunc with schema (c1 integer, c2 float, c3 double, c4 bigint), the query returns the relation.
<query id="qColtAggr60"><![CDATA[ select winsorizedMean(c3, c1, c1) from SColtAggrFunc ]]></query>
Timestamp Tuple 10 1, 0.5, 40.0, 8 1000 0, 0.7, 30.0, 6 1200 1, 0.89, 20.0, 12 2000 1, 0.4, 10.0, 4 h 8000
Timestamp Tuple Kind Tuple -9223372036854775808:+ 10: - 10: + 40.0 1000: - 40.0 1000: + 35.0 1200: - 35.0 1200: + 30.000000000000004 2000: - 30.000000000000004 2000: + 25
