java.lang.Math FunctionsThis chapter provides a reference to the java.lang.Math functions provided in Oracle Continuous Query Language (Oracle CQL).
For more information, see .
This chapter includes the following section:
java.lang.Math FunctionsTable 12-1 lists the built-in java.lang.Math functions that Oracle CQL provides.
Table 12-1 Oracle CQL Built-in
Built-in function names are case sensitive and you must use them in the case shown (in lower case).
In stream input examples, lines beginning with h (such as h 3800) are heartbeat input tuples. These inform Oracle Stream Explorer that no further input will have a timestamp lesser than the heartbeat value.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html.
Syntax
Purpose
abs returns the absolute value of the input integer argument as an integer.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#abs(int).
Examples
Consider the query q66. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q66"><![CDATA[ select abs(c1) from SFunc ]]></query>
Timestamp Tuple 10 1,0.5,8 1000 -4,0.7,6 1200 -3,0.89,12 2000 8,0.4,4
Timestamp Tuple Kind Tuple 10: + 1 1000: + 4 1200: + 3 2000: + 8
Syntax
Purpose
abs1 returns the absolute value of the input long argument as a long.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#abs(long).
Examples
Consider the query q67. Given the data stream SFunc with schema (c1 integer, c2 float, c3 long), the query returns the stream.
<query id="q67"><![CDATA[ select abs1(c3) from SFunc ]]></query>
Timestamp Tuple 10 1,0.5,8 1000 4,0.7,-6 1200 3,0.89,-12 2000 8,0.4,4
Timestamp Tuple Kind Tuple 10: + 8 1000: + 6 1200: + 12 2000: + 4
Syntax
Purpose
abs2 returns the absolute value of the input float argument as a float.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#abs(float).
Examples
Consider the query q68. Given the data stream SFunc with schema (c1 integer, c2 float, c3 bigint), the query returns the stream.
<query id="q68"><![CDATA[ select abs2(c2) from SFunc ]]></query>
Timestamp Tuple 10 1,0.5,8 1000 4,-0.7,6 1200 3,-0.89,12 2000 8,0.4,4
Timestamp Tuple Kind Tuple 10: + 0.5 1000: + 0.7 1200: + 0.89 2000: + 0.4
Syntax
Purpose
abs3 returns the absolute value of the input double argument as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#abs(double).
Examples
Consider the query q69. Given the data stream SFunc with schema (c1 integer, c2 float, c3 bigint, c4 double), the query returns the stream.
<query id="q69"><![CDATA[ select abs3(c4) from SFunc ]]></query>
Timestamp Tuple 10 1,0.5,8,0.25334 1000 4,0.7,6,-4.64322 1200 3,0.89,12,-1.4672272 2000 8,0.4,4,2.66777
Timestamp Tuple Kind Tuple 10: + 0.25334 1000: + 4.64322 1200: + 1.4672272 2000: + 2.66777
Syntax
Purpose
acos returns the arc cosine of a double angle, in the range of 0.0 through pi, as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#acos(double).
Examples
Consider the query q73. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q73"><![CDATA[ select acos(c2) from SFunc ]]></query>
Timestamp Tuple 10 1,0.5,8 1000 4,0.7,6 1200 3,0.89,12 2000 8,0.4,4
Timestamp Tuple Kind Tuple 10: + 1.0471976 1000: + 0.79539883 1200: + 0.4734512 2000: + 1.1592795
Syntax
Purpose
asin returns the arc sine of a double angle, in the range of -pi/2 through pi/2, as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#asin(double).
Examples
Consider the query q74. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q74"><![CDATA[ select asin(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.5235988 1000: + 0.7753975 1200: + 1.0973451 2000: + 0.41151685
Syntax
Purpose
atan returns the arc tangent of a double angle, in the range of -pi/2 through pi/2, as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#atan(double).
Examples
Consider the query q75. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q75"><![CDATA[ select atan(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.4636476 1000: + 0.61072594 1200: + 0.7272627 2000: + 0.3805064
Syntax
Purpose
atan2 converts rectangular coordinates (x,y) to polar (r,theta) coordinates.
This function takes the following arguments:
double1: the ordinate coordinate.
double2: the abscissa coordinate.
This function returns the theta component of the point (r,theta) in polar coordinates that corresponds to the point (x,y) in Cartesian coordinates as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#atan2(double,%20double).
Examples
Consider the query q63. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q63"><![CDATA[ select atan2(c2,c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.7853982 1000: + 0.7853982 1200: + 0.7853982 2000: + 0.7853982
Syntax
Purpose
cbrt returns the cube root of the double argument as a double.
For positive finite a, cbrt(-a) == -cbrt(a); that is, the cube root of a negative value is the negative of the cube root of that value's magnitude.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#cbrt(double).
Examples
Consider the query q76. Given the data stream SFunc with schema (c1 integer, c2 float, c3 bigint), the query returns the stream.
<query id="q76"><![CDATA[ select cbrt(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.7937005 1000: + 0.887904 1200: + 0.9619002 2000: + 0.73680633
Syntax
Purpose
ceil1 returns the smallest (closest to negative infinity) double value that is greater than or equal to the double argument and equals a mathematical integer.
To avoid possible rounding error, consider using (long) cern.jet.math.Arithmetic.ceil(double).
For more information, see:
Examples
Consider the query q77. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q77"><![CDATA[ select ceil1(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 1.0 1000: + 1.0 1200: + 1.0 2000: + 1.0
Syntax
Purpose
cos returns the trigonometric cosine of a double angle as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#cos(double).
Examples
Consider the query q61. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q61"><![CDATA[ select cos(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.87758255 1000: + 0.7648422 1200: + 0.62941206 2000: + 0.921061
Syntax
Purpose
cosh returns the hyperbolic cosine of a double value as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#cosh(double).
Examples
Consider the query q78. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
tkdata140.cqlx, data/inpSColtFunc.txt, log/outSColtcosh.txt
<query id="q78"><![CDATA[ select cosh(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 1.127626 1000: + 1.255169 1200: + 1.4228927 2000: + 1.0810723
Syntax
Purpose
exp returns Euler's number e raised to the power of the double argument as a double.
Note that for values of x near 0, the exact sum of expm1(x) + 1 is much closer to the true result of Euler's number e raised to the power of x than EXP(x).
Examples
Consider the query q79. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q79"><![CDATA[ select exp(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 1.6487212 1000: + 2.0137527 1200: + 2.4351296 2000: + 1.4918247
Syntax
Purpose
expm1 returns the computation that Figure 12-1 shows as a double, where x is the double argument and e is Euler's number.
Figure 12-1 java.lang.Math Expm1
Note that for values of x near 0, the exact sum of expm1(x) + 1 is much closer to the true result of Euler's number e raised to the power of x than exp(x).
Examples
Consider the query q80. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q80"><![CDATA[ select expm1(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.6487213 1000: + 1.0137527 1200: + 1.4351296 2000: + 0.49182472
Syntax
Purpose
floor1 returns the largest (closest to positive infinity) double value that is less than or equal to the double argument and equals a mathematical integer.
To avoid possible rounding error, consider using (long) cern.jet.math.Arithmetic.floor(double).
Examples
Consider the query q81. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q81"><![CDATA[ select floor1(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.0 1000: + 0.0 1200: + 0.0 2000: + 0.0
Syntax
Purpose
hypot returns the hypotenuse (see Figure 12-2) of the double arguments as a double.
Figure 12-2 java.lang.Math hypot
double1: the x value.
double2: the y value.
The hypotenuse is computed without intermediate overflow or underflow.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#hypot(double,%20double).
Examples
Consider the query q82. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q82"><![CDATA[ select hypot(c2,c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.70710677 1000: + 0.98994946 1200: + 1.2586501 2000: + 0.56568545
Syntax
Purpose
IEEEremainder computes the remainder operation on two double arguments as prescribed by the IEEE 754 standard and returns the result as a double.
double1: the dividend.
double2: the divisor.
The remainder value is mathematically equal to f1 - f2 × n, where n is the mathematical integer closest to the exact mathematical value of the quotient f1/f2, and if two mathematical integers are equally close to f1/f2, then n is the integer that is even. If the remainder is zero, its sign is the same as the sign of the first argument.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#IEEEremainder(double,%20double).
Examples
Consider the query q72. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q72"><![CDATA[ select IEEEremainder(c2,c2) from SFunc ]]></query>
Syntax
Purpose
log1 returns the natural logarithm (base e) of a double value as a double.
Note that for small values x, the result of log1p(x) is much closer to the true result of ln(1 + x) than the floating-point evaluation of log(1.0+x).
Examples
Consider the query q83. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q83"><![CDATA[ select log1(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + -0.6931472 1000: + -0.35667497 1200: + -0.11653383 2000: + -0.9162907
Syntax
Purpose
log101 returns the base 10 logarithm of a double value as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#log10(double).
Examples
Consider the query q84. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q84"><![CDATA[ select log101(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + -0.30103 1000: + -0.15490197 1200: + -0.050610002 2000: + -0.39794
Syntax
Purpose
log1p returns the natural logarithm of the sum of the double argument and 1 as a double.
Examples
Consider the query q85. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q85"><![CDATA[ select log1p(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.4054651 1000: + 0.53062826 1200: + 0.63657683 2000: + 0.33647224
Syntax
Purpose
pow returns the value of the first double argument (the base) raised to the power of the second double argument (the exponent) as a double.
double1: the base.
double2: the exponent.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#pow(double,%20double).
Examples
Consider the query q65. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q65"><![CDATA[ select pow(c2,c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.70710677 1000: + 0.7790559 1200: + 0.9014821 2000: + 0.69314486
Syntax
Purpose
rint returns the double value that is closest in value to the double argument and equals a mathematical integer. If two double values that are mathematical integers are equally close, the result is the integer value that is even.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#rint(double).
Examples
Consider the query q86. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q86"><![CDATA[ select rint(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.0 1000: + 1.0 1200: + 1.0 2000: + 0.0
Syntax
Purpose
round returns the closest integer to the argument.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#round(float).
Input/Output Types
The input/output types for this function are as follows:
| Input Type | Output Type |
DOUBLE |
DOUBLE |
INTEGER |
INTEGER |
FLOAT |
FLOAT |
BIGINT |
BIGINT |
BIGDECIMAL |
BIGDECIMAL |
Examples
Consider the query q87. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q87"><![CDATA[ select round(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 1 1000: + 1 1200: + 1 2000: + 0
Syntax
Purpose
round1 returns the closest integer to the float argument.
Examples
Consider the query q88. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q88"><![CDATA[ select round1(c2) from SFunc ]]></query>
Syntax
Purpose
signum returns the signum function of the double argument as a double:
zero if the argument is zero
1.0 if the argument is greater than zero
-1.0 if the argument is less than zero
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#signum(double).
Examples
Consider the query q70. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q70"><![CDATA[ select signum(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 1.0 1000: + -1.0 1200: + -1.0 2000: + 1.0
Syntax
Purpose
signum1 returns the signum function of the float argument as a float:
-1.0 if the argument is less than zero.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#signum(float).
Examples
Consider the query q71. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the relation.
<query id="q71"><![CDATA[ select signum1(c2) from SFunc ]]></query>
Syntax
Purpose
sin returns the trigonometric sine of a double angle as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#sin(double).
Examples
Consider the query q60. Given the data stream SFunc with schema (c1 integer, c2 float, c3 bigint), the query returns the stream.
<query id="q60"><![CDATA[ select sin(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.47942555 1000: + 0.64421767 1200: + 0.7770717 2000: + 0.38941833
Syntax
Purpose
sinh returns the hyperbolic sine of a double value as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#sinh(double).
Examples
Consider the query q89. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q89"><![CDATA[ select sinh(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.5210953 1000: + 0.75858366 1200: + 1.012237 2000: + 0.41075233
Syntax
Purpose
sqrt returns the correctly rounded positive square root of a double value as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#sqrt(double).
Examples
Consider the query q64. Given the data stream SFunc with schema (c1 integer, c2 float, c3 bigint), the query returns the stream.
<query id="q64"><![CDATA[ select sqrt(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.70710677 1000: + 0.83666 1200: + 0.9433981 2000: + 0.6324555
Syntax
Purpose
tan returns the trigonometric tangent of a double angle as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#tan(double).
Examples
Consider the query q62. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q62"><![CDATA[ select tan(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.5463025 1000: + 0.8422884 1200: + 1.2345995 2000: + 0.42279324
Syntax
Purpose
tanh returns the hyperbolic tangent of a double value as a double.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#tanh(double).
Examples
Consider the query q90. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q90"><![CDATA[ select tanh(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.46211717 1000: + 0.6043678 1200: + 0.7113937 2000: + 0.37994897
Syntax
Purpose
todegrees converts a double angle measured in radians to an approximately equivalent angle measured in degrees as a double.
The conversion from radians to degrees is generally inexact; do not expect COS(TORADIANS(90.0)) to exactly equal 0.0.
Examples
Consider the query q91. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q91"><![CDATA[ select todegrees(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 28.64789 1000: + 40.107044 1200: + 50.993244 2000: + 22.918312
Syntax
Purpose
toradians converts a double angle measured in degrees to an approximately equivalent angle measured in radians as a double.
Examples
Consider the query q92. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q92"><![CDATA[ select toradians(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 0.008726646 1000: + 0.012217305 1200: + 0.0155334305 2000: + 0.006981317
Syntax
Purpose
ulp returns the size of an ulp of the double argument as a double. In this case, an ulp of the argument value is the positive distance between this floating-point value and the double value next larger in magnitude.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#ulp(double).
Examples
Consider the query q93. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the stream.
<query id="q93"><![CDATA[ select ulp(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 1.110223E-16 1000: + 1.110223E-16 1200: + 1.110223E-16 2000: + 5.551115E-17
Syntax
Purpose
ulp1 returns the size of an ulp of the float argument as a float. An ulp of a float value is the positive distance between this floating-point value and the float value next larger in magnitude.
For more information, see http://java.sun.com/javase/6/docs/api/java/lang/Math.html#ulp(float).
Examples
Consider the query q94. Given the data stream SFunc with schema (c1 integer, c2 double, c3 bigint), the query returns the relation.
<query id="q94"><![CDATA[ select ulp1(c2) from SFunc ]]></query>
Timestamp Tuple Kind Tuple 10: + 5.9604645E-8 1000: + 5.9604645E-8 1200: + 5.9604645E-8 2000: + 2.9802322E-8
