emctl exportconfig oms [-sysman_pwd <sysman password>]
Exports a snapshot of the OMS configuration to the specified directory. It is recommended to save the configuration details in a secure location and to save it every time there is a change in the configuration. These details will be required during a system recovery.
The parameter descriptions are as below:
-oms_only : Specifies the OMS-only backup on Administration server host.
-keep_host : Specifies that the host name will also be a part of the backup if no SLB is defined. Use this option only if recovery will be done on a machine that responds to this host name.
emctl importconfig oms -file <backup file> [-no_resecure] [-sysman_pwd <sysman password>] [-reg_pwd <registration password>]
Imports the OMS configuration from the specified backup file. This command is used during a system recovery. The parameter descriptions are as below:
-file <backup file> : Indicates the backup file to import from.
-no_resecure : Specifies that the system will not re-secure OMS after the import is complete. The default is to re-secure the OMS after the import is complete.
emctl config emrep [-sysman_pwd <sysman password>]
Configures the OMS and repository target. This command is used to change the monitoring Agent for the target and/or the connection string used to monitor this target. The parameter descriptions are as below:
-agent <new agent> : Specifies a new destination agent for the emrep target
-conn_desc [<jdbc connect descriptor>] : Updates Connect Descriptor with the specified value. If the value is not specified, it is taken from the stored value in emoms.properties .
-ignore_timeskew: Ignores time skew on Agents.
emctl config repos [-sysman_pwd <sysman password>]
Configures the repository database target. This command is used to change the monitoring Agent for the target and/or the monitoring properties (host name, Oracle Home and connection string used to monitor this target). The parameter descriptions are as below:
-agent <new agent>: Specifies a new destination agent for the repository target.
-host <new host>]: Specifies a new host name for the repository target.
-oh <new oracle home>: Specifies a new Oracle home for the repository target.
emctl enroll oms [-as_host <host>] -as_port <port> - as_pws <admin password> -nm_pwd <nodemanager password>
Enrolls the OMS on to the specified Administration Server host. This command is used in the process of recovering an OMS in a multi-OMS environment. The parameter descriptions are as below:
-as_port <port>: Specifies the Administration Server secure port.
-as_pwd <admin password> : Specifies the Administration Server password.
-nm_pwd <nodemanager password>: Specifies the node manager password.
