To configure the connector:
From the Setup menu of the Enterprise Manager console as Super Administrator, select Extensibility, then Management Connectors.
The Management Connectors page appears, which lists all created connector instances.
The connector is already configured if a green checkmark appears in the Status column.
Click on the name of the OMU Connector.
The General tab of the Configure Management Connector page appears, as shown in Figure 3-2.
Provide the required settings. See Providing General Settings for details.
Click OK.
The Management Connectors page reappears. The row for the OMU Connector should have a check mark in the Configured column.
If you chose HTTPS as the protocol to establish a connection between OMU and Enterprise Manager, make sure you have performed the steps specified in Configuring Enterprise Manager to Use SSL.
Figure 3-2 Configure Management Connector Page
