Siebel Remote and Replication Manager Administration Guide > Reference Materials for Siebel Remote >
Field Descriptions for Administration Screens
This topic describes fields that you can use in the administration screens that you use with Siebel Remote. It includes the following information:
Fields in the Siebel Remote Client Status Form
Table 39 describes fields of the Siebel Remote Client Status form.
Table 39. Fields of the Siebel Remote Client Status Form
Extracted on Server |
Last Sessions |
Time when Siebel Remote extracted this client. |
Seconds |
Amount of time required to extract the remote client. |
File name |
First file name for the extracted records. |
Rows extracted |
Row count of extracted records. |
Snapshot (Kbytes) |
Total size in kilobytes for extracted records. |
# of Files in File System |
Number of files in file system for this client. |
File System (Kbytes) |
Size of files in file system, in kilobytes. |
Max Transaction |
Maximum transaction ID when Siebel Remote extracted this client. |
Initialized on Client |
Last Session |
Time when Siebel Remote initialized the local database. |
Seconds |
Amount of time required to initialize the local database. |
Free Disk (Kbytes) |
Free disk space available of the local computer where you installed the remote client. |
Database (Kbytes) |
The size in kilobytes of the local database. |
Number of files in the local file system. |
Total size in kilobytes of files in the local file system. |
Product Version |
System information for the computer where the local database resides. |
Current status |
Last Session |
Time when Siebel Remote performed the last synchronization. |
Seconds |
Duration of the last synchronization. |
Database (Kbytes) |
Current size of the local database. |
Current size in kilobytes of files in the local file system. |
Total Sessions |
Total number of times this client has synchronized so far. |
Product Version |
Current system information for the remote client. |
Fields in the Siebel Remote Client Diagnostics Form
Table 40 describes fields of the Siebel Remote Client Diagnostics form.
Table 40. Fields of the Siebel Remote Client Diagnostics Form
Name |
Node name. |
Type |
INIT, ROUTE, RECEIVE, MERGE, CLEAN, SESSION. |
Local |
Flag to indicate it is for current or local databases. |
Created |
The time that Siebel Remote created the record. |
Last updated |
The time that Siebel Remote last updated the record. |
Last file |
The last file number that Siebel Remote processed for the node. |
Last transaction id |
The last transaction number that Siebel Remote processed for the node. |
Last trxn duration (sec) |
The time required to process transaction in the latest session. |
Total duration (sec) |
Total time required to process transaction for the node. |
Last trxn size (bytes) |
Size of transactions processed for the node during last session. |
Total (bytes) |
Total size of transactions processed for the node. |
Last trxn operations |
Number of operations processed for the node during last session. |
Total operations |
Total number of operations processed for the node. |
Last transactions |
Number of transactions processed for the node during last session. |
Total transactions |
Total number of transactions processed for the node. |
Total attachment (bytes) |
Total size of file attachments processed for the node. |
Total attachments |
Total number of file attachments. |
Last attachment (bytes) |
Size of file attachments for the node during the last session. |
Last attachments |
Number of file attachments for the node during the last session. |
Additional information |
More detailed information about the node. |
Fields in the Synchronization Sessions List
Table 41 describes fields in the Synchronization Sessions list.
Table 41. Fields in the Synchronization Sessions List
Synchronization Starts |
Date and time when Siebel Remote started the synchronization. |
Synchronization Ends |
Date and time when the synchronization ended. If the synchronization did not complete successfully, then this field is empty. |
Transactions |
The number of transactions that Siebel Remote synchronized to the user during the session. |
Transaction Size (MB) |
The total size in MB of the transactions that Siebel Remote synchronized to the user during the session. |
Client Merge Duration (Min) |
The amount of time in minutes required to merge transactions on client. |
Fields in the Siebel Remote Upload Statistics Form
Table 42 describes fields in the Siebel Remote Upload Statistics form.
Table 42. Fields in the Siebel Remote Upload Statistics Form
Last Session |
Last File |
Last transaction file that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server. |
Last Transaction |
Last transaction that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server. |
Transaction Count - Last |
Number of transactions that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server during the last synchronization. |
Transaction Count - Total |
Total transactions that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server since the last database extract. |
Operation Count - Last |
Number of operations that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server during the last synchronization. |
Operation Count - Total |
Total number of operations that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server since the last database extract. |
KBytes - Last |
Size of transactions that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server during the last synchronization, in kilobytes. |
KBytes - Total |
Size of transactions that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server since the last database extract, in kilobytes. |
Duration (Seconds) - Last |
Duration of last synchronization that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server, in seconds. |
Duration (Seconds) - Total |
Total duration of all synchronizations since the last database extract, in seconds. |
Attachment Files - Last |
Number of file attachments that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server during the last synchronization. |
Attachment Files - Total |
Number of file attachments that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server since the last database extract. |
Attachment Size (KBytes) - Last |
Size of file attachments that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server during the last synchronization, in kilobytes. |
Attachment Size (KBytes) - Total |
Size of files that Siebel Remote created on the remote client, received on the Siebel Server, or applied on the Siebel Server since the last database extract, in kilobytes. |
Fields in the Siebel Remote Download Statistics Form
Table 43 describes fields in the Siebel Remote Download Statistics form.
Table 43. Fields in the Siebel Remote Download Statistics Form
Last Session |
Date and time of last session that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client. |
Last File |
Last transaction file that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client. |
Last Transaction |
Last transaction that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client. |
Number of transactions that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client during the last synchronization. |
Total transactions that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client since the last database extract. |
Number of operations that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client during the last synchronization. |
Total number of operations that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client since the last database extract. |
KBytes - Last |
Size of transactions that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client during the last synchronization, in kilobytes. |
KBytes - Total |
Size of transactions that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client since the last database extract, in kilobytes. |
Duration of the last synchronization, in seconds. |
Total duration of all synchronizations since the last database extract of the node, in seconds. |
Attachment File Count - Last |
Number of file attachments that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client during the last synchronization. |
Attachment File Count - Total |
Number of file attachments that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client since the last database extract of this node. |
Size of the file attachments that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client during the last synchronization. |
Size of all file attachments that Siebel Remote created on the Siebel Server, received on the remote client, or applied on the remote client since the last database extract of this node. |
Operation Types for the Operation Field of the Transaction Log List
Table 44 describes operation types for the Operation Field of the Transaction Log list.
Table 44. Operation Types for the Operation Field of the Transaction Log List
A |
Data Definition Language (DDL) statement. Indicates a database schema update. |
B |
Delete a dock object instance. A data merge deletes all member table rows only for a server to client operation. |
C |
Delete a record as a result of deleting a dock object instance for a server to client only. |
D |
Delete single row. |
E |
Delete multiple rows. |
F |
Delete cascading rows. |
G |
Merge multiple rows. |
H |
Insert a record as a result of downloading a dock object instance only for a server to client operation. |
I |
Insert single row. |
J |
Contain transactions in an external file. |
K |
Marker transaction to indicate the start of client-side transaction. |
L |
Update to the record of a child table that might cause conflict. |
M |
Marker transaction to stop processing a user and then continue. |
N |
Compensation operation for client-side merge (CSM) or cascade delete transaction that the W operation performs. The purpose of the compensation operation is to remove any orphan child records that exist in the Siebel database that resulted from a remote client-side merge or cascade delete on the client database. |
O |
Operation to update conflict ID. |
P |
Simple Data Manipulation Language (DML) statement that uses pass through. |
Q |
Delete records of a child table that match the foreign key value. This operation is a compensation operation that Siebel Remote creates as the result of client-side merge (CSM) or a cascade delete transaction that the W operation performs. The purpose of the Q operation is to clean up any orphan child records that exist in the Siebel Server as a result of CSM or cascade delete in the remote client. |
R |
Update the foreign key column of child table records. |
S |
Shadow operation. |
T |
Delete records of a child table that might cause conflict. |
U |
Update a single row. |
V |
Update multiple rows. |
W |
Compacted operation of cascade or client-side merge. |
X |
Insert set-based rows. |
Y |
Update set-based rows. |
Z |
Delete set-based rows. |
