Siebel Remote and Replication Manager Administration Guide > Reference Materials for Siebel Remote > Server Component Parameters >
Parameters of the Replication Agent Server Component
Table 38 describes the parameters of the Replication Agent server component.
Table 38. Parameters of the Replication Agent Server Component
Parameter
Alias
Required
Description
HQ Application Server Comm param
CommParam
Optional
The colon-separated list of communications parameters that the regional server uses to connect to the parent Siebel Server.
HQ Application Server Name
HQ
Required
The Dock Connect String of the parent Siebel Server. For more information, see Setting the HQ Application Server Name Parameter.
Iterations
Iterations
Optional
Specifies the number of times that the Replication Agent server component connects to the parent node.
You typically set this parameter to zero (0) to configure the Replication Agent to loop forever or until the server administrator stops it.
If you set the Iterations parameter to 1 and then start Replication Agent, then a single synchronization occurs.
The default value is 0.
Maximum txns per commit
MaxCommitTxns
Optional
Specifies the number of transactions that Siebel Remote applies before it commits these transactions to the Siebel database.
The default value is 100.
Maximum writes per file
MaxWrite
Optional
Limits the size of a DX file. Breaks the DX files that Siebel Remote sends to the parent Siebel Server into smaller, more manageable files.
Replication Manager closes the existing DX file and then starts writing to a new DX file when the current DX file reaches the maximum number of operations that you specify in the Maximum writes per file parameter.
The default value is 10000.
Receive files
RecvFiles
Optional
You can use one of the following values:
  • TRUE. Replication Manager receives the file attachments that the parent Siebel Server sends to the Siebel Server of the regional node.
  • FALSE. Replication Manager does not receive the file attachments that the parent Siebel Server sends to the Siebel Server of the regional node.
The default value is TRUE.
Receive txns
RecvTxns
Optional
  • TRUE. Replication Manager receives the DX files that the parent Siebel Server sends to the Siebel Server of the regional node.
  • FALSE. Replication Manager does not receive the DX files that the parent Siebel Server sends to the Siebel Server of the regional node.
Send txns
SendTxns
Optional
  • TRUE. Replication Manager sends DX files from the Siebel Server on the regional node to the parent Siebel Server.
  • FALSE. Replication Manager does not send DX files from the Siebel Server on the regional node to the parent Siebel Server.
Sleep time
SleepTime
Optional
The time period, in seconds, that configures Replication Agent to sleep between synchronizations.
The default value is 60.
Siebel Remote and Replication Manager Administration Guide Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices.
