Go to main content
Oracle® Developer Studio 12.6: Performance Library User's Guide
Exit Print View
Updated: July 2017
Mathematical Routines
Oracle Developer Studio Performance Library routines are used to solve the following types of linear algebra and numerical problems:
  • Elementary vector and matrix operations – Vector and matrix products; plane rotations; 1, 2-, and infinity-norms; rank-1, 2, k, and 2k updates
  • Linear systems – Solve full-rank systems, compute error bounds, solve Sylvester equations, refine a computed solution, equilibrate a coefficient matrix
  • Least squares – Full-rank, generalized linear regression, rank-deficient, linear equality constrained
  • Eigenproblems – Eigenvalues, generalized eigenvalues, eigenvectors, generalized eigenvectors, Schur vectors, generalized Schur vectors
  • Matrix factorizations or decompositions – SVD, generalized SVD, QL and LQ, QR and RQ, Cholesky, LU, Schur, LDLT, UDUT, and CS Decomposition
  • Support operations – Condition number, in-place or out-of-place transpose, inverse, determinant, inertia, extra-precise iterative refinement
  • Sparse matrices – Solve symmetric, structurally symmetric, and unsymmetric coefficient matrices using direct methods and a choice of fill-reducing ordering algorithms, and user-specified orderings
  • Convolution and correlation in one and two dimensions
  • Fast Fourier transforms, Fourier analysis and Fourier synthesis, cosine and quarter-wave cosine transforms, cosine and quarter-wave sine transforms
  • Complex vector FFTs and FFTs in two and three dimensions
  • Sorting operations
  • CBLAS Interface
