The Oracle Developer Studio Performance Library was compiled using the f95 compiler provided with this release. The Oracle Developer Studio Performance Library routines were compiled using -dalign, -xparallel.
When linking the program, use -dalign -library=sunperf and the same command line options that were used when compiling.
Oracle Developer Studio Performance Library is linked into an application with the -library switch rather than the -l switch that is used to link in other libraries, as shown here.
my_system% f95 -dalign my_file.f -library=sunperf
When linking your program, use -library=sunperf and the same command line options that were used when compiling. If you compile on a SPARC system, include the option -xmemalign=8s as shown here. The -xmemalign=8s option is ignored on x86 and x64 platforms.
my_system% cc -xmemalign=8s my_file.c -library=sunperf my_system% CC -xmemalign=8s my_file.cpp -library=sunperf
If -dalign or -xmemalign=8s cannot be used for compilation, supply a trap 6 handler as described in Enabling Trap 6 on SPARC Platforms.
