Table of Contents
1. Preface
1.1 Prerequisites
1.2 Audience
1.3 Conventions Used
2. Installing WebServices Database Objects
3. Deploying Application Interface WebServices
3.1 Creating Data Sources for WebServices
3.2 Working with SSL
3.2.1 Steps to Import Certificates to keystore
3.2.2 Enable SSL Debugging
3.2.3 Connecting to service supporting only TLS protocol
3.3 Create RouteOne Credentials and System Policies
3.4 Deploying Webservices
3.4.1 Deployment of WebServices in Enterprise Manager
4. Configuring Weblogic Policy on WebServices
5. Verifying Successful Installation
5.1 Steps to Verify Successful Webservices deployment:
5.2 Steps to Verify Successful Interface (Route One) deployment:
6. Enable Logging
6.1 Enabling WebService Log
6.2 Enabling SQL Log for WebServices Component
7. Configure AQ-JMS Bridge
7.1 Create Data Sources for AQ-JMS Bridge
7.2 Configure MDB Flow
7.3 Create Credentials and System Policies
7.4 Deploy MDB EJB
8. Configuring RESTful WebService
8.1 Create Data Sources for RESTful WebService
8.2 Deploy RESTful WebService
9. Appendix - Configuration parameters
