| Field | Description |
External Payroll ID |
Payroll ID generated from a third-party payroll system. |
OS User Name |
Employee’s Microsoft Windows account user name for using POS devices on the Restaurant Enterprise Series (RES) system. |
OS Domain Name |
Microsoft Windows domain name for the RES POS system. |
Employee Role |
For environments that include Oracle MICROS Simphony, you can set the employee role when creating the employee, but you cannot make changes through Labor Management. To change the role for an existing employee, use the Simphony Enterprise Management Console (EMC). |
Exclude from EU Directives |
Indicates if European Union directives do not apply to the employee. This setting is valid only for systems in member states of the European Union. |
OT Exempt |
Enable if the employee does not qualify for overtime work and pay. |
Employee Level |
Employee Level is used to control the access of other employee records when a user is logged into the EMC. Level 0 is highest and 9 is the lowest. An employee assigned Level 4 cannot see records for employees with Levels 0-3. |
Allow Sub Minimum Wage |
Enable if the employee is eligible for a pay rate below the minimum wage standard. For example, enable the setting for an employee who receives tips. |
In City Limits |
Employee address is within the city limits of the store location. |
Lives on Property |
Employee address is where the employee resides. |
Unlisted |
Excludes the employee phone number from the Employee Phone List report. |
Opt Out |
Labor Management does not send email notifications to the employee. For example, Labor Management does not send a notification to the employee when a manager approves a schedule. |
To specify a flat or percentage amount to be deposited to a bank account, select the Amount Type and then enter the respective Amount. For example, if an employee provides two bank accounts and wants a 30 percent and 70 percent split, you can select and enter Percentage and 30 for the first bank and Percentage and 70 for the second bank.
If the total amount paid through direct deposit does not constitute the entirety of the paycheck, select Balance. For example, if an employee provides a bank account for direct deposit but only wants 70 percent of their paycheck deposited to the bank account, select this option.
Is Salaried |
Indicates the employee receives a salary. Enter a monthly or an annual salary amount. |
Job Rates tab |
Add Job Rate |
Adds a job or pay rate. Enter job and pay rate details, and then click Update List. |
Skill Level Requirement |
Employee proficiency at fulfilling job requirements. |
Primary Job |
Indicates the selected job is the employee’s primary job at the location. |
Exclude from Staff Requirements |
Labor Management does not include the employee when calculating staffing requirements. |
Exclude from Scheduler |
Employee and corresponding job do not appear in the editor when adjusting schedules. |
Default Pay Rate Applies |
Labor Management uses the pay rates configured for the job. Or, you can enter an Override Pay Rate to enter a pay rate for the employee. |
Parent topic: Employee Management
